 Post subject: RDS Separate output
PostPosted: Sun Jul 24, 2011 10:59 pm
I know that stereotool has a powerful stereo generator but there are people like me who prefers the external hardware stereo generator. So it would be great if stereotool had an mpx output including only the RDS signal. So with one soundcard I can send audio to the external stereo generator, and another soundcard I could send the RDS to the stereo generator to make the multiplex.
Also only for "image" reason it could be great if there is something like "home" screen showing only the processing bars much bigger.
John
 Post subject: Re: RDS Separate output
PostPosted: Sun Jul 24, 2011 11:14 pm
Actually you can do that easily!
Just disable 50us, Pre-Emphasize outout and Encode Stereo. Ofcourse "Encode RDS" ON. On FM out you'll have only RDS signal and you can put it into your SCA input on stereo coder.
