 Post subject: New preset Hot(LOUD)
PostPosted: Sun Jul 24, 2011 8:15 pm
Hello, Its my first time post here.
Here is our preset from YOUFM Patras.
This preset was created from the begining (Not based on another preset)
Ok, it need some fixing but here its the first edition.
Its a HOT&Loud type (our radio station is targeted in young people).
John
JOHNB HOT AC (LOUD N PROUD).zip [2.96 KiB]
Downloaded 771 times
 Post subject: Re: New preset Hot(LOUD)
PostPosted: Sun Aug 07, 2011 4:04 pm
Ok, I made some changes to reduce all the "chaos" caused by loudness. Also I made new settings to the Loudness. Also I reduced the stereo expander and setup the stereo image mode.
Hope you like. Im open for comments or something that you believe its good to fix.
John
JOHNB HOT AC (LOUD N PROUD)B1.zip [2.99 KiB]
Downloaded 813 times
