PostPosted: Sun Jun 19, 2011 12:31 am
Take a look here:
http://www.claessonedwards.com/forum/vi ... f=5&t=2023
(Please answer here, if you are not an active member of the claessonedwards forum).
PostPosted: Sun Jun 19, 2011 6:37 am
Is "Use oversampling to avoid inter-sample peaks" enabled? (Top right of the Loudness&Limiting window)
And HARD LIMIT?
PostPosted: Sun Jun 19, 2011 7:28 am
And HARD LIMIT?
Both are enabled.
But it makes no difference if "Use oversampling to avoid inter-sample peaks" is enabled or not.
The chain inside BA Live looks like this:
Stereo Tool :arrow: VB:FFX 4 hosting the to DX wrapped (old Cakewalk VST adpater) TT DR meter VST plugin.
So the output of Stereo Tool (with post amp - 1.00 dB) goes straight to TT DR meter (and this shows correctly - 1.00 dB as max peak).
So the BA Live peak limiter gets this signal (no doubt !).
If I set post amp in ST to +0.08 dB the TT DR meter shows "over" for peak and the BA Live meters shows purple flames (but not if I use +0.00 for post amp).
PostPosted: Sun Jun 19, 2011 3:58 pm
Problem solved !
It was the BA Live high pass filter (20 Hz - activated by default during BA Live installation).
Details here:
http://www.claessonedwards.com/forum/vi ... b0d#p10550
