PostPosted: Mon May 02, 2011 7:03 pm
Stereo Tool both v6.00 and v6.10 (VST) won't work with Cubase 6.0.1 (Win 7 32bit)
When i try to load Stereo Tool as an insert VST, it's like Stereo Tool is hogging the system.
After 10+ seconds only an empty plugin window shows up (this is the first and only instance - see picture).
Also, i can't load Stereo Tool VST in Wavelab v6.1.
Wavelab hangs on initial Stereo Tool popup (window with registration info.)
However, Stereo Tool stand alone version works correctly.
Does anybody have a clue what's going on ?
