PostPosted: Sat Mar 19, 2011 8:48 am
Since beta version 620-013 the start window in vst version is empty.
But it is only the first window, when you start stereotool, the other looks like they are working
I use vst version as plug in wavelab 6
PostPosted: Sat Mar 19, 2011 12:38 pm
Ok, seen and confirmed. I'll try to fix it asap.
Edit: No time for a build now. I've overwritten the BETA620-017 VST version (only the SSE2 version, not the NonSSE2 version)
PostPosted: Sat Mar 19, 2011 2:51 pm
oh ok , i see than i am not alone to have the problem :mrgreen:
PostPosted: Sat Mar 19, 2011 4:02 pm
Problem is solved, will be fixed in the next BETA.
