Hello, I have a small suggestion. Each function or filter usually has a small earpiece icon next to it or on the item itself. The purpose is supposed to be to listen to the changes made by that function or adjustment individually. However, if you forget to cancel it and return to the home screen, or if you have too many earpieces open and forget which one you forgot to turn off, you can't get back to normal and have to search for each item one by one. Is there a button or inequality sign that can turn off all earpieces or individual monitoring functions? Otherwise, if someone else presses it, searching for each item is tedious. Or does this function already exist but I'm not aware of it? Or is it possible to automatically turn it off when leaving a specific item?
I hope my questions aren't too numerous...
