 Post subject: est1337's attempt
PostPosted: Mon Aug 11, 2025 6:12 am
Hi, I've been playing around with Stereo Tool lately. I built this preset from scratch, by studying various presets and the behaviours of the prcoessor. This preset is made for CHR formats and has mild compression. P.S I still don't fully understand the wideband compressor. Some people may or may not like this type of sound.
I ask for your feedback on the preset. Go as hard on the criticism as you want, as long as it is constructive!
est1337s attempt - 2025-08-11.sts [166.35 KiB]
Downloaded 324 times
 Post subject: Re: est1337's attempt
PostPosted: Wed Aug 13, 2025 2:11 pm
Hi Est
For a beginner tweaker you've actually done ok!
I wouldn't put it to air on FM but certainly mastering or just listening.. sure!
There are a few things that aren't optimal
1) attack times on your MB 1-2ms.. way to quick!
2) very little limiting
Try to strike a balance between compression and limiting rather then just compressing the life out of it.
PostPosted: Sat Aug 16, 2025 9:05 am
Hi, I've made some improvements to the multiband and limiting. Let me know
est1337s attempt v1.1.sts [181.24 KiB]
Downloaded 268 times
PostPosted: Sun Aug 17, 2025 5:20 am
More improvements to the multiband. Less compression
est1337s attempt v1.2.sts [181.15 KiB]
Downloaded 283 times
PostPosted: Sun Aug 17, 2025 5:43 am
Very good.. keep going
Turn off WB compressor and your MB2.. they aren't being utilized so you might as well turn them off
The Bass clipping needs some work
Keep in mind you dont want to limit the Low Frequencies to much as the more the Bass clipper gets more punchy the audio will sound.
PostPosted: Sun Aug 17, 2025 6:25 am
wb and mb2 reconf with bass clipper adjustments
est1337s attempt v1.3.sts [181.17 KiB]
Downloaded 254 times
PostPosted: Sun Aug 17, 2025 6:29 am
quick fix to make the bass slightly less prominent
est1337s attempt v1.3.1 bass fix.sts [181.17 KiB]
Downloaded 307 times
PostPosted: Mon Aug 18, 2025 9:53 pm
Liking this.
PostPosted: Wed Aug 20, 2025 2:13 pm
Getting better.
I tweaked you preset very quickly with not such much errors but more things that are a bit counter productive
1) turned off FM broadcast... If your not outputting this into a transmitter turn it off
2) Turned off your MB2 and WB
3) Changed your gain structure
4) Changed your AGC to a Multiband AGC
5) Changed your Stereo delay .. 6ms is too quick for the human ear... 13-14ms is a better start
6) Changed the gain and cross over of your Bass clipper
There was a few other things I changed but 90% is still your settings.
If you want to learn more about what does what there are some good youtube videos with
Mike Ericson from Wheatstone, Cornelius Gould From Angry Audio and even from The Man Hans himself
est1337 - est1337_s attempt v1.3.1 tweaked - 2025-08-20.sts [191.64 KiB]
Downloaded 320 times
