 Post subject: Recorder
PostPosted: Wed Jun 18, 2025 3:06 am
Recorder.
I'd like to request that ST would have a Recorder just like the one that is found on Break Away One. It's really useful for me and I believe it will be for others too.
 Post subject: Re: Recorder
PostPosted: Fri Nov 28, 2025 4:27 pm
We have FFmpeg integration in the latest beta's. Once we finalize that and make it more user friendly to use, using it as a recorder is definitely on our list. For now, you can already write the audio to a file in those beta's, but you need to fiddle a bit with command line parameters.
cat {OUT1} > /tmp/file.pcm
would do it in the output (writing raw 16 bit PCM bytes).
