Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
 Post subject: Stereo Tool 10.51 BETA
PostPosted: Sat Feb 08, 2025 11:26 am
Hi all,
Latest version - Beta 10.51-012 (Feb 24 2025)
Note: Version number says "10.51", but this is not yet the released version!
Note 2: RIST and AES67 are disabled in this build! (More testing and code fine-tuning is needed for releasing both).
Downloads
Changes/bugfixes
  • TEST case: proxy URL's
  • Added downloading of built-in presets
  • TEST case: Check JSON interface pressing buttons!
  • TEST case: software update STXtreme
  • TEST json token default login rights (manually verified)
TODO's
  • Login doesn't work between web and native GUI for users > Admin
  • TEST create account and log in and out, for Stereo Tool and for Enterprise, also for instance 2
  • TEST links sound card page STXtreme front panel - can we go there?
  • Bug fix (10.40): Offset in web interface for empty elements in boxes.
  • Don't open on Overview if there's only 1 instance
  • AM Brilliance demo file
  • MultiVOC Jack version more than 2 channels
  • MicroMPX: On our SD card image, it doesn't show the NIC for ETH0 in the pulldown menu - why??? Works fine in other images.
  • MacOS: GUI doesn't move unless the window size is changed (VST2, VST3, stand alone not tested)
  • Check if input affinities are set
  • RIST is NOT compatible with other vendors - why??
  • AES67 Do we want to also support the system clock, including any offsets that are applied to it? Probably not?
  • AES67: Add PTP incoming time smoothing
  • AES67: Add to STXtreme (FM)
  • TEST multi-instance web and native GUI (incl. ListManagers)
  • TEST popup multicast network
  • Probably disable AES67 and RIST before release
  • File player for top-of-hour legal ID (for both MicroMPX and ST)
  • For Pi 5, change default block size to 4096!
  • UMPX TESTS F
  • MicroMPX v5: RTP
  • MicroMPX v5: RIST
  • MicroMPX v5: Improve quadrature encoding for very clean signals to avoid rounding errors in peak level detection.
  • MicroMPX v5: Email joost 2
  • NEW BUILD SYSTEM
  • Directly after new build system: Put PhoneBooster in VST plugins
  • Directly after new build system: Add VST Linux support
  • Directly after new build system: Add AU support
  • Check reported "Socket error" in output stream. Apparently new in 10.50 but I don't know if that's true. https://support.thimeo.com/scp/tickets.php?id=9990
  • Create automatic test: TEST create account and log in and out, for Stereo Tool and for Enterprise, also for instance 2. Also test JSON token.
  • Streaming blocks if now playing file drive is unreachable (10.21): viewtopic.php?t=33962
  • Linux: "Full screen" mode - after closing the software opens without a GUI. Workaround added, real fix needed later.
  • Potential AAC streaming issue on Pi: viewtopic.php?p=77926
  • MicroMPX monitoring tool
  • Create C++ version of SNMP monitoring tool for Pi SD card image
  • Check minimum requirements for AES67 output
  • K Black Pi RDS2 issue - fine on Windows, potentially ARM code error
  • Bug: HD output level is reduced when using BS412. Has been this way forever...
  • Add libVLC support to Linux/Mac builds (for OS parity)
  • Pi image: Check Pi memory patch
  • Check VST3 crash on Mac TOM
  • Check VST in Auditon on Mac TOM
  • MicroMPX: Export the control signal that would control when the backup player becomes active to the JSON and library outputs so GPO's can be coupled to it.
  • Web interface KoekError display: Add last error time to web interface. But NOT for MicroMPX, because there the time is already part of the error message - or change that, but identical messages must still be logged separately in that case.
  • Output streaming via libVLC is broken; it does not detect when there's no connection, and does not detect connection loss in VLCGetBuffers. So it does not properly reconnect after an error.
  • Add PhoneBooster to VST
  • Flights + location Vegas
  • Check Norway, book hotel/flights
  • Upload new manuals
  • JSON interface documentation
  • Check Hard Limit behavior (Bojcha)
  • Add + button for streams, to make page less crowded
  • Maybe support AI translations - but how?
  • MicroMPX: When signal comes back, backup player stops and silence is played, can be 14 seconds if that's the buffer size.
  • Vorbis: Add sample rate; if we're running at 192 kHz that's also the stream sample rate, should be 48 in that case.
  • MicroMPX Add way to set IP address - but how??
  • Re-enable MPX demodulator settings in Stereo Tool (MPX Tool-like)
  • STXtreme 5 FM instances doesn't work if more than 2 are set to latency 128. Do more measurements and figure out what the limits are.
  • STXtreme: Implement smart glitch detection INTERNALLY so we don't need to run external tests all the time. Maybe we can already see it!
  • STXtreme multi-instance hiccups system Matt - why?
  • STXtreme: Audio seems fine even though buffer display shows that the buffer is very low.
  • MicroMPX: Add/modify JSON parameter that shows total used bitrate to include RIST, plus number of RIST clients.
  • Matrix mode: Make a setting to never reduce stereo - Wait for feedback Mathijs
  • MicroMPX: Add way to set IP address of hardware
  • Multple streams: Support different metadata??
  • MicroMPX decoder: RIST: Figure out way to get rid of RIST delay, or how to sync with non-RIST and how to specify RIST vs non-RIST delays - LATER
  • MicroMPX decoder: RIST: How to handle RIST delay in combination with GPS
  • Would it be possible to make an R128 measurement there, where I can set the measurement period for a sliding window between 1 and about 5 minutes?
  • MicroMPX: Reduce RIST overhead
  • Clipper + Hard Limit makes the spectrum dirty, mainly for pure sine waves - but why?
  • STXtreme: Add loopback test for handling brief power drops. BUSY
  • MicroMPX library: umpxDecoderDecryptAnalysePacket may try to decode a packet while internally a packet is already being decoded, causing threading issues.
  • MillingBroadcast's MicroMPX speed issue with encoder in Stereo Tool on Linux: viewtopic.php?f=14&t=34583&p=77454#p77454 - Waiting for feedback
  • Silence detector in ST with email/SMS?
  • Bojcha (via Discord personal chat with images): Clipper (measured HD out, no pre-emphasis) has HOLE between 5kHz and 13kHz about 0.4dB. Only way to fix it is to set Highs clipping from +1.51dB (default) to +0.95dB. He says it sounds better too... (less gaps due to highs, not less highs)
  • MicroMPX: Add GPS support for decoder without NMEA. That's how others do it - they just use the timestamp in the packet as the time of the closest 1PPS pulse. Will simplify the hardware!
  • MicroMPX: Silence detection in MPX is used to switch between studios! So reporting levels is really necessary.
  • Mathijs: Als je de AGC in Matrix mode gebruikt (trouwens voor MB hetzelfde denk ik), dan wil je eigenlijk channel linking gebruiken om te voorkomen dat L-R heel extreem bijgetrokken wordt tov L+R. Alleen: als dan de hoeveelheid stereo content flink toeneemt kan het zijn dat L-R de L+R mee omlaag trekt, en dat wil ik eigenlijk niet. Dat gebeurt sneller als je ook nog die "Stereo boost when AGC is below threshold" setting gebruikt. Zou fijn zijn als die channel link maar één kant op kan werken; dus dat L+R altijd vrij kan bewegen en dat L-R daar aan vast gelinkt hangt
  • Vinyl bass rumble removal
  • NAN's show up sometimes, why???
  • Report that VST3 on Mac crashes on startup
  • Sound cards: Add VLC to input 2 for backup - but that requires a fix for when the stream drops out.
  • MicroMPX overview app
  • Remove Stokkemask Clipper?
  • Soms geeft "GetSamplesScrollSize" -1 terug, omdat scrolled[index] 0 is. Dat wijst op een issue met updaten van de waveform op momenten dat dat niet nodig is. Op dat moment doet 'ie dus onnodig een volledige redraw. In debugmode gebeurt dat vaak.
  • Streaming: Add FLAC support
  • Test SDI
  • Analyzer
  • I/O: AES67
  • Add RDS2 slide shows
  • Streaming must read data from files from a separate thread, viewtopic.php?p=75718
  • Fix Declipper issues reported in viewtopic.php?f=14&t=33774&start=30 and on Discord
  • MicroMPX: Run as service?
  • PEQ in MicroMPX FM output?
  • VMware licensing 2w
  • M. mails! + Contract
  • Add capture output soundcard??? (Wasapi loopback?)
  • Startup delay on MicroMPX?
  • Update LiquidSoap links
  • Auto pilot
  • Maybe add some frequency display to MPX display. viewtopic.php?f=16&t=33720
  • Add numeric displays to ITU and MPX levels in GUI viewtopic.php?f=16&t=33686
  • gStreamer AES67?
  • Azimuth affects highs!!
  • Add PWarnMini for Diff
  • MicroMPX: Show temperature
  • Win10 scheduler appears to ignore ideal CPU cores since last (few) update(s)
  • Mac: VST2 sizes
  • Mac: gavinmcgrath: "Intel MacOS 11.7.3 in Wavelab 11.1: Blank screen." viewtopic.php?f=14&t=33391&p=73407#p73407
  • Stand alone RDS decoder
  • PDcWave delay not set
  • Flashing peq/mb eq bars in GUI
  • Software update requires Admin rights
  • Add latency wizard?
  • Matt: FM+AM
  • Check EQMB_SCOPES
Latest version - Beta 10.51-011 (Feb 22 2025)
Downloads
Changes/bugfixes
  • Check suppression of "Deprecated settings" message, both when loading built-in presets AND when doing that on initial startup (PiMP, STAMP) -> Suppression code was there, but not enabled!
  • Web interface issues 10.50 TOM
  • AES67: Fix SDP download in web interface TOM
  • PiMP etc default latency is 0 ms, which cannot work. Increased to 0.3 ms. And overall (for all the software), buffer size 0 is treated as 1 notch above 0, because 0 is always bad.
  • TEST case: upload preset
  • TEST case: download preset
  • Test 2wcom RIST compatibility Failed
Latest version - Beta 10.51-009 (Feb 20 2025)
Downloads
Changes/bugfixes
  • AES67: "Export SDP" was accidentally always visible, and other AES67 visibility settings are also wrong.
  • Put firmware update on SD card image!! And measure performance effect -> 28% lower CPU usage on a Pi 5, and 4096 mode works fine now - default setting should be changed! To be tested on a Pi 4.
  • Single-channel input now outputs on both channels instead of left-only (right channel silence). For example useful for MultiVOC, which can now output a microphone signal twice.
Latest version - Beta 10.51-008 (Feb 19 2025)
Downloads
Changes/bugfixes
  • Web interface title is missing
  • AES67 create SDP generator - works internally, download via weg gui not yet
Latest version - Beta 10.51-007 (Feb 18 2025)
Downloads
Changes/bugfixes
  • AES67 output: Added QoS mode.
  • AES67 output: Fixed internal clock display (not proper system time, but time since boot).
  • AES67: Set TTL output to 32 hops, which is the default for AES67.
  • AES67 output clock must be monotonous clock, not real clock.
  • AES67 out needs to bind to specific NIC, also to make QoS work.
  • AES67: Add to STXtreme (HD)
  • AES67: For low latency, couple output to input? So we won't need any resampling and can keep perfect track of latencies.
  • MicroMPX: Trigger auto-restart on "RIST: Socket error". https://support.thimeo.com/scp/tickets.php?id=10711 Test feedback wanted!
  • Adaptive Compressor: Optimized Peak mode performance (CPU usage now depends on "CPU target" setting, 70% less for Pi 3/4, 40% less for STXtreme, same as before for "Insane").
  • Web interface issues in 10.50 partially fixed, but not yet fully.
Latest version - Beta 10.51-003 (Feb 11 2025)
Downloads
Changes/bugfixes
  • AES67 output: Added 1-channel 192 kHz MPX out.
  • Added automatic build test: boot SD card image to all different versions; check version number and I/O working
Latest version - Beta 10.51-002 (Feb 8 2025)
Downloads
Changes/bugfixes
  • Added experimental AES67 to HD output - works with Axia LiveWire driver and Stereo Tool AES67 input, but nothing else has been tested yet. Only 24 bit stereo supported for now. TEST!
  • Pi SD card updater: REMOVE XKB dependency that was added in 10.50 for all Linux builds, which caused problems in our SD card image.
  • Check report that libVLC input keeps repeating same few seconds on dropout. https://www.facebook.com/groups/4716335 ... &ref=notif -> Solved, also improved reconnect behavior
  • GUI: In 10.50, sometimes some texts are not shown, making it unclear what a slider does.
PostPosted: Sat Feb 08, 2025 3:07 pm
I'm testing aes67 out HD, I immediately noticed something, the channel is not published in the livewire selector of the axia driver (screenshoot 2) but it plays regularly, the flow is acquired regularly by the axia driver, it is not just displayed.
I'm keeping it in test.
the text display bug seems to be solved (screenshoot 3).
PostPosted: Sat Feb 08, 2025 6:07 pm
Ah, right. We only implemented AES67, and announcing channels isn't part of the standard.
PostPosted: Sat Feb 08, 2025 6:09 pm
Listened for 2 hours continuously, audio and buffer ok
PostPosted: Sat Feb 08, 2025 9:09 pm
Can you open up detailed settings and check which clock it's using? So in Stereo Tool, go to the HD output and click the > . It should either state PTP or System clock; if it's PTP I'm also curious what it shows in adjustment values.
PostPosted: Sat Feb 08, 2025 9:58 pm
here it is....
As I wrote you some time ago everything must be clocked with the master clock, everything correct.
I share with you this little box that costs little and does its job.
Audio transmitter / receiver on Ethernet, MasterClock, compatible with AES67
https://www.hasseb.fi/shop2/index.php?r ... duct_id=66
PostPosted: Sun Feb 09, 2025 12:44 am
Hi, I meant the HD settings in Stereo Tool. There's a display there that should show which clock it uses, and how accurate it is. (This device might be useful though).
PostPosted: Sun Feb 09, 2025 8:44 am
hi,
you see it in the first screenshot of the first post, I'll attach it again.
link short video
https://www.mediafire.com/file/wdcnuvlb ... 4.mp4/file
PostPosted: Sun Feb 09, 2025 1:21 pm
Ok, your values look similar to mine - are you using that hardware clock?? Because I just tested with a PTP master in a VMware image, which I wouldn't expect to be very accurate at all.
Either way, I want to add some code to smooth clock differences. Typically, you'll often see a large negative value followed by a similar positive value, indicating that that first clock came in (or was handled!) too late. That's easy to fix, I'll probably look at it on Monday.
In other good news: We now have an automatic test framework, not just for the processing (we already had that), but now also for the web interface. Which among others now automatically tests that all the different programs on the Pi image are successfully starting. We used to test that manually before, but we've sometimes missed things (it turns out that 10.50 Stereo Tool doesn't work on the latest version of our image, oops). More tests will be added, we have a list of things to test, and from now on, for everything that breaks we will create a test case.
PostPosted: Sun Feb 09, 2025 1:49 pm
hi,
there is something wrong with the channel publication, not all the livewire channels appear in the "DEVICE" field, if I manually insert one of the visible channels in the axia driver it plays it but in the device field it says "ENUM INVALID" if I close and reopen stereo tool it takes the first available channel and not the last one inserted (manually).
