Hi. I'm just a hobbyist and don't broadcast, so I can't say for 100 percent certain, but I would bet it is possible to use ST to process the outgoing audio.
What is your playout software and how are you sending audio out? This will determine the easiest way to go about it.
Some support DSP or VST plugins and can work that way.
Otherwise I figure you'll need to use a virtual soundcard like Virtual Audio Cable or VBcable to tunnel the standalone ST to your broadcast platform.
