PostPosted: Wed Feb 05, 2025 5:21 am
... I'm missing some info. Several Cumulus stations in my area are all using what is likely the loudest/densest preset the Omnia Volt has to offer. I would like to try my hand at some point in porting this over to Stereo Tool, however I am missing information about the 5-band AGC and 5-band limiter crossover frequencies. That is not listed in the manual. Also broadcastengineering.info no longer exists so I cannot ask there.
Does anyone here know either the default crossover or centre-frequencies for the bands of the Volt?
Side note: Any mathematical formula for converting crossover points to band centre and vice-versae? I've had to visually determine on the graph where the crossover points go because (Band A + Band B)/2 isn't really getting the right results.
