PostPosted: Wed Dec 18, 2024 10:26 pm
Hello,
When I import a preset into the latest version of stereo tool, all the preset settings are inactive. Is this normal and how can I solve this problem?
Thanks in advance for your answers
PostPosted: Thu Dec 19, 2024 1:13 am
Hello,
In 10.41? Are you using a plugin or the standalone and what version and OS? I vaguely remember an issue that sounds like this, but I thought it was fixed in 10.41.
You can try the latest beta (currently 10.42 found here https://forums.stereotool.com/viewtopic ... 14&t=34592) and see if it's fixed there.
PostPosted: Tue Jan 14, 2025 1:07 pm
Hello, after trying to update the software, the parameters are still disabled when importing a preset, is there another solution to the problem?
PostPosted: Tue Jan 14, 2025 6:59 pm
Which type are you using again (VST, DSP, Stand Alone)? And what's your OS (and plugin host if applicable)?
This sounds like a bug. Is the preset able to be loaded in an older version properly? As in, are all the expected modules enabled? What version last worked?
PostPosted: Tue Jan 14, 2025 8:50 pm
The latest functional version is not available, and even with the latest version of the software it doesn't work. It's vst presets with Windows 10, it's the software installed on Windows directly.
PostPosted: Wed Jan 15, 2025 11:13 pm
Interesting. You said VST, so the preset was exported from VST and into the Stand Alone?
To clarify, it's that modules aren't enabled when loading the preset? Or is it something to do with the sliders being greyed out, despite the modules being enabled?
I'm wondering if the preset itself isn't the issue. Perhaps it can shed light on what's happening. Could you upload the preset so it can be checked out?
PostPosted: Fri Jan 17, 2025 9:10 am
Here's the link to the presets (these are sts files) : https://dropover.cloud/f654da
PostPosted: Fri Jan 17, 2025 10:54 pm
I tried these and they work as expected in the Stand Alone, version 10.42 beta055. Please give the latest beta another try.
Could you answer the other questions as well?:
is it that modules aren't enabled when loading the preset? Or is it something to do with the sliders being greyed out, despite the modules being enabled?
