Post new topic  Reply to topic  [ 112 posts ]  Go to page 1 2 3 4 512 Next
 Post subject: Stereo Tool 10.42 BETA
PostPosted: Tue Oct 08, 2024 11:48 am
Hi all,
Latest version - Beta 10.42-059 (Jan 24 2025)
Downloads
Changes/bugfixes
  • Stereo Tool: Add a time stamp to error messages. Add field to KoekError
  • Mac version leaks memory, at least with GUI minimized. https://support.thimeo.com/scp/tickets. ... 3193#reply Tom
  • Remove Legacy Peak mode after testing (keep for debugging)
  • MicroMPX decoder: support multicast IP and NIC selection via RIST
  • PORTAUDIO: REVERTED SUSPICIOUS COMMIT 0e9b386a1053261340bc8bb32335484ef77b258b, WAIT FOR FEEDBACK FROM DIMOS -> NOPE, WASN'T IT.
TODO's
  • Made top menu the default for new users, and increased the default window size a bit so the main (overview/home) page fits nicely.
  • Change Adaptive Bass Monster presets (normal)
  • Change version number
  • Contract TD
  • Check new presets
  • RELEASE
    FOR 10.51:
  • Added experimental AES67 to HD output - works with Axia LiveWire driver and Stereo Tool AES67 input, but nothing else has been tested yet. Only 24 bit stereo supported for now. TEST!
  • REMOVE XKB dependency TEST!
  • Check report that libVLC input keeps repeating same few seconds on dropout. https://www.facebook.com/groups/4716335 ... &ref=notif
  • GUI: Sometimes some texts are not shown, making it unclear what a slider does.
  • TEST multi-instance web and native GUI (incl. ListManagers)
  • TEST login multi-instance and single instance
  • TEST json token default login rights
  • TEST links sound card page STXtreme front panel - can we go there?
  • TEST software update STXtreme
  • TEST check feedback 10.50
  • TEST popup multicast network
  • TEST download preset
  • TEST boot SD card image to all different versions
  • TEST proxy URL's
  • Web interface issues 10.50
  • AES67: Add QoS
  • AES67: Add time smoothing
  • Potential AAC streaming issue on Pi: viewtopic.php?p=77926
  • MicroMPX monitoring tool
  • Create C++ version of SNMP monitoring tool for Pi SD card image
  • Check minimum requirements for AES67 output
  • K Black Pi RDS2 issue - fine on Windows, potentially ARM code error
  • Bug: HD output level is reduced when using BS412. Has been this way forever...
  • Add libVLC support to Linux/Mac builds (for OS parity)
  • Pi image: Check Pi memory patch
  • Check VST3 crash on Mac TOM
  • Check VST in Auditon on Mac TOM
  • MicroMPX: Export the control signal that would control when the backup player becomes active to the JSON and library outputs so GPO's can be coupled to it.
  • Web interface KoekError display: Add last error time to web interface. But NOT for MicroMPX, because there the time is already part of the error message - or change that, but identical messages must still be logged separately in that case.
  • Output streaming via libVLC is broken; it does not detect when there's no connection, and does not detect connection loss in VLCGetBuffers. So it does not properly reconnect after an error.
  • Add PhoneBooster to VST
  • Flights + location Vegas
  • Check Norway, book hotel/flights
  • Upload new manuals
  • JSON interface documentation
  • Check Hard Limit behavior (Bojcha)
  • Add + button for streams, to make page less crowded
  • Maybe support AI translations - but how?
  • MicroMPX: When signal comes back, backup player stops and silence is played, can be 14 seconds if that's the buffer size.
  • Vorbis: Add sample rate; if we're running at 192 kHz that's also the stream sample rate, should be 48 in that case.
  • MicroMPX Add way to set IP address - but how??
  • Re-enable MPX demodulator settings in Stereo Tool (MPX Tool-like)
  • STXtreme 5 FM instances doesn't work if more than 2 are set to latency 128. Do more measurements and figure out what the limits are.
  • STXtreme: Implement smart glitch detection INTERNALLY so we don't need to run external tests all the time. Maybe we can already see it!
  • STXtreme multi-instance hiccups system Matt - why?
  • STXtreme: Audio seems fine even though buffer display shows that the buffer is very low.
  • MicroMPX: Add/modify JSON parameter that shows total used bitrate to include RIST, plus number of RIST clients.
  • Matrix mode: Make a setting to never reduce stereo - Wait for feedback Mathijs
  • MicroMPX: Add way to set IP address of hardware
  • Multple streams: Support different metadata??
  • MicroMPX decoder: RIST: Figure out way to get rid of RIST delay, or how to sync with non-RIST and how to specify RIST vs non-RIST delays - LATER
  • MicroMPX decoder: RIST: How to handle RIST delay in combination with GPS
  • Would it be possible to make an R128 measurement there, where I can set the measurement period for a sliding window between 1 and about 5 minutes?
  • MicroMPX: Reduce RIST overhead
  • Clipper + Hard Limit makes the spectrum dirty, mainly for pure sine waves - but why?
  • STXtreme: Add loopback test for handling brief power drops. BUSY
  • MicroMPX library: umpxDecoderDecryptAnalysePacket may try to decode a packet while internally a packet is already being decoded, causing threading issues.
  • MillingBroadcast's MicroMPX speed issue with encoder in Stereo Tool on Linux: viewtopic.php?f=14&t=34583&p=77454#p77454 - Waiting for feedback
  • Silence detector in ST with email/SMS?
  • Bojcha (via Discord personal chat with images): Clipper (measured HD out, no pre-emphasis) has HOLE between 5kHz and 13kHz about 0.4dB. Only way to fix it is to set Highs clipping from +1.51dB (default) to +0.95dB. He says it sounds better too... (less gaps due to highs, not less highs)
  • MicroMPX: Add GPS support for decoder without NMEA. That's how others do it - they just use the timestamp in the packet as the time of the closest 1PPS pulse. Will simplify the hardware!
  • MicroMPX: Silence detection in MPX is used to switch between studios! So reporting levels is really necessary.
  • Mathijs: Als je de AGC in Matrix mode gebruikt (trouwens voor MB hetzelfde denk ik), dan wil je eigenlijk channel linking gebruiken om te voorkomen dat L-R heel extreem bijgetrokken wordt tov L+R. Alleen: als dan de hoeveelheid stereo content flink toeneemt kan het zijn dat L-R de L+R mee omlaag trekt, en dat wil ik eigenlijk niet. Dat gebeurt sneller als je ook nog die "Stereo boost when AGC is below threshold" setting gebruikt. Zou fijn zijn als die channel link maar één kant op kan werken; dus dat L+R altijd vrij kan bewegen en dat L-R daar aan vast gelinkt hangt
  • Vinyl bass rumble removal
  • NAN's show up sometimes, why???
  • Report that VST3 on Mac crashes on startup
  • Sound cards: Add VLC to input 2 for backup - but that requires a fix for when the stream drops out.
  • MicroMPX overview app
  • Remove Stokkemask Clipper?
  • Soms geeft "GetSamplesScrollSize" -1 terug, omdat scrolled[index] 0 is. Dat wijst op een issue met updaten van de waveform op momenten dat dat niet nodig is. Op dat moment doet 'ie dus onnodig een volledige redraw. In debugmode gebeurt dat vaak.
  • Streaming: Add FLAC support
  • Test SDI
  • Analyzer
  • I/O: AES67
  • Add RDS2 slide shows
  • Streaming must read data from files from a separate thread, viewtopic.php?p=75718
  • Fix Declipper issues reported in viewtopic.php?f=14&t=33774&start=30 and on Discord
  • MicroMPX: Run as service?
  • PEQ in MicroMPX FM output?
  • VMware licensing 2w
  • M. mails! + Contract
  • Add capture output soundcard??? (Wasapi loopback?)
  • Startup delay on MicroMPX?
  • Update LiquidSoap links
  • Auto pilot
  • Maybe add some frequency display to MPX display. viewtopic.php?f=16&t=33720
  • Add numeric displays to ITU and MPX levels in GUI viewtopic.php?f=16&t=33686
  • gStreamer AES67?
  • Azimuth affects highs!!
  • Add PWarnMini for Diff
  • MicroMPX: Show temperature
  • Win10 scheduler appears to ignore ideal CPU cores since last (few) update(s)
  • Mac: VST2 sizes
  • Mac: gavinmcgrath: "Intel MacOS 11.7.3 in Wavelab 11.1: Blank screen." viewtopic.php?f=14&t=33391&p=73407#p73407
  • Stand alone RDS decoder
  • PDcWave delay not set
  • Flashing peq/mb eq bars in GUI
  • Software update requires Admin rights
  • Pens
  • Add latency wizard?
  • Matt: FM+AM
  • Check EQMB_SCOPES
  • libVLC with FDK???
Latest version - Beta 10.42-058 (Jan 23 2025)
Downloads
Replace links with 1042-058
Changes/bugfixes
  • Adaptive mode Peak compressor speeds up or something when going deeper - why???? - Made a mode where for extreme spikes we briefly switch over to near-RMS mode which doesn't have this issue. If this doesn't break anything, remove old setting (waiting for feedback).
  • Some warning popups are shown on STXtreme, which were hidden before - now it turns out that a calculation was wrong, which we never noticed because the popup wasn't displayed. Fixed.
  • Web server: JSON replies are broken
  • Web server: Added initial support (not yet active) to request data from multiple instances in a single request.
  • Create shortcut for Start with windows with path set to Program Files path, so Kantar watermarking files etc can be found. -> Not really important, Enterpprise fixes this by filling in paths already. Legacy only, for existing users.
  • GPS has wrong icon in native GUI, ok in web interface. TOM
  • Could not connect streaming error is incorrectly snoozed after updating it. Exceptions (force exception) too!
  • Webinterface broke in previous beta (may or may not have caused issues based on timing).
  • MicroMPX enabled state is wrong if FM on, Stereo/RDS off.
Latest version - Beta 10.42-055 (Jan 12 2025)
Downloads
Replace links with 1042-055
Changes/bugfixes
  • Big build system cleanup and web server code rewrite/cleanup (needed for better multi-instance support). Could be risky.
  • Web interface: Downloading presets didn't work.
  • Auto-fill Song for streaming from Artist + Title, with checkbox to enable this.
  • Mac streaming still doesn't work for some reason - Was an M1/2/3 problem, should be fixed now.
  • MicroMPX: Added ability to remove RDS completely. Will lead to bad peak protection!
  • Password protection didn't work in native GUI for non-Enterprise builds
  • Translations: Fixed infinite loop which could make everything extremely slow.
  • Downloading presets is broken in the web interface
Latest version - Beta 10.42-052 (Dec 25 2024)
Downloads
Replace links with 1042-052
Changes/bugfixes
  • MicroMPX: RIST: Don't send recovery packets
  • Translation of pulldown texts caused GUI 100% CPU usage.
  • Update MicroMPX manual for RIST
  • Declipper plugin: "Check VST2 Perfect Declipper VST in Reaper, report that 64 bit doesn't work, 32 is fine. -> Works fine in VSTHost." -> Works fine here now, added to downloads.
Latest version - Beta 10.42-051 (Dec 24 2024)
Downloads
Replace links with 1042-051
Changes/bugfixes
  • MicroMPX decoder: RIST: Add confgurable recovery buffer (how?)
  • MicroMPX decoder: RIST: Fix crash when blocking callback during switching between inputs, also could cause hangups when changing or closing.
  • MicroMPX: Fixed possible hangup when switching between non-RIST ports, introduced when adding RIST support.
  • MicroMPX decoder: RIST: Create fake port number for matching packets to encoders
  • Updated Adaptive Bass Monster preset, better bass, better highs on FM.
  • Preset loading: Fix "Contains Streaming outputs settings=0", was without s (broke when adding multiple streams)
  • Multiple streams: Report that only 1st stream has metadata (strange, waiting for confirmation). - Verified with ShoutCast1 server that metadata is sent for multiple streams. This must be another issue.
Latest version - Beta 10.42-050 (Dec 22 2024)
Downloads
Replace links with 1042-050
Changes/bugfixes
  • MicroMPX: RIST mode 2 and 3 didn't work from Stereo Tool
  • STXtreme: Added loopback I/O board self-test with auto-reboots for station with power stability issues.
  • MicroMPX: Add missing average bitrate display for stand alone (non-library) version
  • MicroMPX: Add total bitrate display (does not take RIST overhead into account)
  • MicroMPX RIST: Try to work around crash deep in librist: RELEASE was missing, causing memory leak!. New test running.
  • MicroMPX: When disabling stereo encoding in Stereo Tool, the integrated MicroMPX encoder is still told that there is stereo audio. Which probably means that the clipper is running in stereo mode as well, which is also wrong.
  • MicroMPX encoder: GPS checkbox doesn't get disabled when GPS signal disappears. And GPS will keep sending forever, which is probably bad. -> Does not reproduce here. Some GPS encoders may keep giving time stamps with no signal, maybe that's what happened?
  • Added fix for testing; remove and delay if it doesn't work.Seen in LiquidSoap on Linux: Stereo Tool generic plugin uses host application name instead of its own name, so it saves under .liquidsoap.presets for example. Might not be so bad; running it in different hosts gives us different files. No current hosts on Linux support more than 1 instance I think.
  • Decide whether to keep or remove "Smart bass clipping (TEST)". -> REMOVED.
  • MicroMPX: Reduced tracing context from 512 to 128 lines
  • MicroMPX encoder: RIST: Added 15-second recovery buffer (hard coded)
Latest version - Beta 10.42-047 (Dec 14 2024)
Downloads
Replace links with 1042-047
Changes/bugfixes
  • MicroMPX: Check GPS mode on Pi, apparently broken - No, must be user error - LEFT channel still contains correct audio, right is latency loopback tone.
  • Very scary fix: A tilt correction mask was being calculated using the first latency seen after startup, instead of the current latency. Could cause extremely weird behavior. This bug must have been there for years, but would be mainly noticeable when mixing multiple latencies in multi-instance.
  • STXtreme: Keeps nagging about deprecated settings after restart?
  • Mac streaming was broken (in 10.41, so basically always)
Latest version - Beta 10.42-046 (Dec 13 2024)
Downloads
Replace links with 1042-046
Changes/bugfixes
  • MicroMPX: RIST: Add other RIST settings: 3 connection methods including "Advanced" which lets you specify a RIST URL
  • MicroMPX: RIST: Add way to connect from client to server
  • MicroMPX: Clean up RIST GUI
  • MicroMPX: Deleting a line in the encoder does not disable it! And afterwards there's no way to access it anymore.
  • Properly integrate RIST logging
Latest version - Beta 10.42-044 (Dec 7 2024)
Downloads
Replace links with 1042-044
Changes/bugfixes
  • Added more streaming outputs; now up to 8 separate streams can be encoded simultaneously. Also moved to a separate page.
Latest version - Beta 10.42-043 (Dec 6 2024)
Downloads
Replace links with 1042-043
Changes/bugfixes
  • STXtreme: Fixed bug in calculation of which CPU cores to use, this makes it more efficient on newer boxes.
  • STXtreme: Added buffer size adjustments for running multiple stations. Up to 5 FM stations seems to work now! (Many) more tests are needed.
  • Airy Highs: Optimized new code.
  • Airy Highs: Which settings can be removed? - None...
  • Airy Highs: Found better default values. Also for Time Spread.
  • Bojcha's clipper mods: Make "Dirty highs" dynamic and replace Airy highs, Sparkling highs with it. - It's already dynamic, combination works better than just Dirty.
  • TEST: Added "Smart bass clipping (TEST)" checkbox under Intermodulation distortion protection - Bass protection. This setting should protect mid-bass against deep bass. (For very loud bass it completely breaks the clipper behavior).
Latest version - Beta 10.42-040 (Dec 3 2024)
Downloads
Replace links with 1042-040
Changes/bugfixes
  • Advanced Clipper: Improved Airy Highs further, and for non-Legacy-mode-from-hell mode, split its behavior from that or Sparkling Highs (the settings of the two influenced each other).
  • VST3 support on Windows broke with the addition of Unicode, fixed.
Latest version - Beta 10.42-039 (Nov 28 2024)
Downloads
Replace links with 1042-039
Changes/bugfixes
  • Unicode support
  • Clipper: Added HPF for even harmonics, can sound bad on bass (BETA035). Not useful, removed again
  • Clipper: Do thing for voices that we did for highs IMD -> Does not appear to work...
  • Updated Airy Highs, should sound much better now. We suggest to raise the "Long" value to increase the effect, that should be safe to do now.
Latest version - Beta 10.42-034 (Nov 7 2024)
Downloads
Replace links with 1042-034
Changes/bugfixes
  • Loading only a single Processing filter was partially resetting other things, such as MB frequencies!!!
  • MicroMPX: List initialization in web interface failed on first startup; unused values were shown.
  • Cleaned up MicroMPX re-subscribe to multicast code from a few beta's ago, behavior should be identical.
Latest version - Beta 10.42-033 (Nov 6 2024)
Downloads
Replace links with 1042-033
Changes/bugfixes
  • Fixed RIST dynamic loading in DSP plugin (032 DSP was completely broken)
  • Streaming libraries dynamic loading from DSP plugin never worked properly. This might fix streaming from the DSP in many hosts!
Latest version - Beta 10.42-032 (Nov 4 2024)
Downloads
Replace links with 1042-032
Changes/bugfixes
  • RIST works on Windows! (Library was updated)
  • Windows XP support broke due to RIST. Solution is to dynamically load RIST, we've now added that for the 32 bit stand alone and the Winamp plugin builds. Let us know if you need any other versions to run on XP.
Latest version - Beta 10.42-031 (Nov 3 2024)
Downloads
Replace links with 1042-031
Changes/bugfixes
  • MicroMPX decoder: Multicast request is done only once; if the network is not yet active at that point nothing happens. So we need to either detect IP changes or re-request continuously. https://support.thimeo.com/scp/tickets. ... 9904#reply -> Doing re-request for all inputs on any network change
  • ABE build removed, now fully dynamically enabled in normal build.
  • MicroMPX decoder: Added multiple priority levels (4 now, we can add more if needed).
  • Pi image: IQaudio was still somewhat broken; after selecting it it was impossible to go back to HifiBerry.
  • Increased Stop Threshold slider maximum values for non-Adaptive mode compressors (only MB1 so far), and maximum is no longer "off".
  • MicroMPX: Some status updates didn't work in web interface, now they do.
Latest version - Beta 10.42-028 (Oct 31 2024)
Downloads
Replace links with 1042-028
Changes/bugfixes
  • Sound card rewrite appears to fail, at least for IQaudio card. https://support.thimeo.com/scp/tickets. ... 6533#reply -> Wrong ID was used, fixed
  • ARM builds: Stereo Tool and MicroMPX now have limited login system.
  • Old preset code completely removed - 174 MB of files!
  • Code cleanup (SST/non-GUI builds merged)
  • Simplified some build defines (somewhat risky change)
  • Display active sample rate in VST plugin
  • MicroMPX: Add UECP: Partially working, update to web interface (feedback) does not yet work; values are only updated if any setting is changed.
  • MicroMPX AM Reprocessor doesn't work if input is mono, but normal decoder does work. https://support.thimeo.com/scp/tickets.php?id=9973 -> PROBABLY tried to stream without stereo AND rds, works fine here with either.
Latest version - Beta 10.42-027 (Oct 30 2024)
Downloads
Replace links with 1042-027
Changes/bugfixes
  • Web interface supports error/warning/question popups now!
  • STXtreme and PiMP/STAMP entering license key broke in 10.40.
  • MicroMPX AM Reprocessor has been broken since version 10.30. There was some audio above the LPF frequency. Filter is now also cleaner and tighter than before.
  • Converted console version to modern presets, old presets are now not used anywhere anymore and can be removed.
  • Highs and AM Brilliance; Added lowpass filter
  • ABE version integration
  • Stokkemask with RDS2: Why is the peak level lower? Check if the filtering is too steep at +/0 75 kHz -> No, cannot be fixed, result of what happens further away (above 105 kHz)
Latest version - Beta 10.42-023 (Oct 18 2024)
Downloads
Replace links with 1042-023
Changes/bugfixes
  • GUI top bar reorganized
  • MicroMPX: RIST: Fix memory issues.
Latest version - Beta 10.42-022 (Oct 17 2024)
Downloads
Replace links with 1042-022
Changes/bugfixes
  • MicroMPX RIST now available through GUI, and adding/removing ports and turning RIST on/off is supported! There are still some memory leaks and the code MIGHT be buggy.
Latest version - Beta 10.42-021 (Oct 16 2024)
Downloads
Replace links with 1042-021
Changes/bugfixes
  • VST bug fix: Detection failed in some hosts because of exceptions. This may solve some VST issues.
  • RIST support for MicroMPX - Decoder port switching works now. Encoder not yet.
  • RIST support for MicroMPX - Decoder waiting for packets code is redesigned, RISKY!
  • Brilliance under Highs is back
  • Code cleanup in framework. Shouldn't change any behavior.
Latest version - Beta 10.42-019 (Oct 14 2024)
Downloads
Replace links with 1042-019
Changes/bugfixes
Latest version - Beta 10.42-017 (Oct 11 2024)
Downloads
Replace links with 1042-017
Changes/bugfixes
  • Big GUI change: Menu on the left can be moved to the right, or removed completely and use a menu in the top bar instead. Go to Application settings -> Graphical settings -> Classical menu menu location.
  • AM Brilliance: Try LPF before MB, directly after (or part of) AM Brilliance. -> Yes, that's better, and also improves HD output if that's also used.
Latest version - Beta 10.42-014 (Oct 8 2024)
Downloads
Replace links with 1042-014
Changes/bugfixes
  • AM Brilliance: Make filter to compensate for phase cancellation at lower Quality settings
  • Split AM Brilliance into a normal Brilliance for processing and a separate one for AM? Wait for feedback. (Was: How do we enable AM Brilliance for AM stations? It's basically a processing setting, or should we move it?)
  • AM Brilliance: Try minimize add filter
PostPosted: Tue Oct 08, 2024 6:10 pm
Suggest that the indicators for Intellelimit in multibands use the "Light accent color". They appear to be hard coded as white currently. When a white background is used, the display shows no action.
Thanks to MrKlorox for the tip!
Great Hits and More!
http://RadioDAVE.US
PostPosted: Tue Oct 08, 2024 7:15 pm
Hello Hans, is it possible to turn on the settings full settings of the adaptive compressor "Multiband2" it gives a more flexible mid-bass. The sound in "AM Brilliance" is almost perfect at the highs, (I feel a more detailed effect).
Once upon a time in assemblies with parallel compression it was enabled, there you could choose a full-fledged one
PostPosted: Tue Oct 08, 2024 8:41 pm
Oh, isn't it? It should be! Chekcing...
Edit: I think all the settings are there - what are you missing?
PostPosted: Tue Oct 08, 2024 9:01 pm
Thanks, I reinstalled the application, and cleared the folder with the old presets and VST-plugin and everything appeared (I was not attentive, there were a bunch of early versions in the plugins folder)
PostPosted: Wed Oct 09, 2024 10:06 pm
For the record: I filed a Liquidsoap bug since saving presets is not working when running ST from the web interface in Liquidsoap. Not sure if this is a Liquidsoap or StereoTool bug, so crossposting the reference here: https://github.com/savonet/liquidsoap/issues/4161
PostPosted: Thu Oct 10, 2024 6:24 pm
under the processing tab the section of levels, loudness and texture seems to be missing in the gui.
don't know if you can see the attachments but st1.png is from 10.41 and st2.png is from 10.42 beta 14.
PostPosted: Fri Oct 11, 2024 10:31 am
BETA017 is posted (not for the multi-instance builds). You can now move the menu on the left to the right, or to the title bar, like it works in the web interface. The latter gives a lot more space and makes the GUI look a lot less intimidating. Go to Application settings -> Graphical settings -> Classical menu menu location.
PostPosted: Fri Oct 11, 2024 12:47 pm
The classical menu location is great, but I miss the volume control with quick adjustment, which I would like to see again with quick adjustment. And is it possible that the extreme tweaker can be in the menu again without the codes Ctrl Shift +
PostPosted: Fri Oct 11, 2024 2:23 pm
Do you mean pre and post amp? Pre amp should not be used anymore (if I had to redesign everything from scratch I wouldn't put that in). There are gain settings for the input sound card, and for AGC/multibands. And in all other processors they do the job. Pre amp basically just affects the first gain slider. (I guess there is something to say for making it available on a quick adjust page... I'll ask around a bit what others think, but generally I would argue that at least a preset shouldn't have it).
