PostPosted: Mon Dec 09, 2024 3:22 pm
Hello, I am trying to activate RDS2 on my StereoTool 10.41 but the stream stops at both 2 decoders (Raspberry PI 4 firmware 4.2.2).
Any idea ?
Kind Regards
PostPosted: Mon Dec 09, 2024 8:02 pm
RDS2 is only supported in the latest version of MicroMPX. Older versions won't understand the data they are receiving. So, update the decoders to the latest version. (4.2.6).
PostPosted: Mon Dec 09, 2024 8:33 pm
Thank you for the information Hans. Where could I find the update file ?
Kind Reagards
PostPosted: Tue Dec 10, 2024 1:38 am
Kind Reagards
The link to the latest release version and instructions are here https://www.thimeo.com/how-to-use-the-r ... ard-image/
Or grab the latest beta update file here https://forums.stereotool.com/viewtopic ... 14&t=34592
PostPosted: Tue Dec 10, 2024 6:11 am
Kind Reagards
Thank you for the information but which files from zip have to upload through the web gui to the PI in order to make the update ? (All of them , one by one ?)
Kind Regards
PostPosted: Mon Feb 24, 2025 1:31 pm
Don't unzip it, just upload the full file through the web interface.
