PostPosted: Thu Oct 24, 2024 7:29 pm
Trying to test the Logo's, where/how do I specify the file location? If I put a drive path, it says can't be found, sending one's.
It is a PNG file 300x300.
Thanks,
Greg
Greg
PostPosted: Fri Oct 25, 2024 12:04 am
Thanks,
Greg
That should work. Please verify the drive path as follows:
- Copy the text in the GUI field to the clipboard
- Open a console window (DOS box)
- In the console window, type cd "paste clipboard text here"
(the quotes need to be there around the paste; you can use the right mouse key to paste)
Then check if it finds the file. If not, you must have made a typo.
