 Post subject: Questions about µMPX
PostPosted: Thu Oct 17, 2024 2:18 pm
We are currently using Stereo Tool to process the audio at our studio before sending it to our transmitters. We are considering upgrading to µMPX. This brings a few questions.
1- If we buy a µMPX licence, how many transmitters can we feed with it?
2- Can we use two network cards on the same computer, connected to two different ISP, to send µMPX to the same destination, to allow for redundancy?
3- For those who run ST on a Windows PC, how do you stay on air 24h /365 days? Do you block updates? Do you have a spare machine?
Thank you all!
Regards
PostPosted: Fri Oct 18, 2024 9:53 am
Hi PaddyC,
Before we used STT to stream over internet to transmitter.
Now we send µMPX over internet.
1 - License to send is include into STT, but you pay a license to receive (one by µMpx decoder running)
2 - you can configure multiple address/port and choose the network used, then YES
3 - µMPX decoder start not as seervice, then you need to be login in to windows desktop to run it. Yes windows update are blocked. Never had a crash of µMpx.
In our case we have often a disconnect and need to restart STT (encoder) to retrieve the connection. Hope that with rist it will be more stable.
PostPosted: Sat Oct 19, 2024 11:07 am
Thank you very much for your aswers, they are very useful. I got an answer from Hans too and he does confirm what you say. I wasn't aware that I could already use µMPX with a ST FM professional license!
We will test it, I hope we don't get as many disconnects as you have.
