PostPosted: Sun Oct 13, 2024 3:18 pm
Made a preset for a friend who likes more gentle processing and he suggested it will be perfect for web streaming (I would it's great for headphone listening too). Uses RMS compression as a less aggressive approach. Should work well with most genres. :)
Martin Petrov Universal Web Radio RMS.sts [168.16 KiB]
Downloaded 621 times
PostPosted: Mon Oct 14, 2024 8:52 pm
Hello friend who loves your favorite bbc presets. I suggest that you listen to this preset that martin set, a song that has great vocal abilities and listen to how it sounds through this martin preset v3 and listen to how it sounds through your favorite bbc preset. You will hear that through the bbc your favorite preset on the chorus is a quieter voice like the instrumental when it is loud. THAT means that this kind of voice gets quieter and then gets louder in the instrumental part of the song. This is the kind of Yugoslav music that you don't play on your stream. Because of things like this, Martin and I experimented with these preset settings. The link for this song is_
https://mega.nz/file/XQthED4Z#xNE0lZPjv ... 5ylW9P7em4
These setting are decent I will say everything is like 25% to maybe 30% to high. When running a a internet radio station having your audio level 8 to 12 db to loud will turn 90% of people away in 5 to 7 seconds. Having your audio 10% to 15% low or high is ok it is way better that being 35% to 50% to quite or to loud.
I have tested like 25 differnet setting my current favorite is
BBC Radio 1... (ish?) https://forums.stereotool.com/viewtopic ... 10&t=33634 v1 is the best
With your Radio Automation software if it has a audio amp or audio setting in the equalizer never set it to + always go with -1 - to -3 and let Stereo Tool do the rest.
