PostPosted: Mon Oct 07, 2024 1:56 pm
Planning to buy this combo for a standalone ST setup. Anybody that can conform this will be a working combo?
PostPosted: Mon Oct 07, 2024 9:13 pm
Hi, are we talking about running an operating system with ST on top of it as an app using something like Jack? I can't imagine why it wouldn't work this way.
Or are you planning on using the Thimeo Raspberry Pi image which turns the Pi into a single-purpose device? If for some reason the DAC2 Pro isn't functionally supported in the image, post about it here and I'm certain the team will try to fix it. The point of the image is to get Thimeo products on the pi with Hifiberry hats as smoothly as possible.
