 Post subject: P2GL 3.0
PostPosted: Tue Sep 17, 2024 7:55 pm
give it a try
It works well on dance traxx and Urban
I was intended to be loud
Still some probs in the highs , working on that !
RDR TEST stream MP3 http://77.251.189.98:8000/MP3HQ
RDR TEST stream FULL MPX in FLAC 192 KHZ http://77.251.189.98:8000/FLACHQ
 Post subject: Re: P2GL 3.0
PostPosted: Wed Sep 18, 2024 7:18 pm
You have forgotten to attach it.
PostPosted: Fri Sep 20, 2024 4:55 pm
Whoops , now i see what happend.
The filesize is to big , so i zipped it .
Demodulated FM audio here ( FLAC stream )
HD audio :
Marthijn de Rooij - P2GL 3.0.zip [128.78 KiB]
Downloaded 531 times
PostPosted: Mon Oct 28, 2024 5:56 pm
Update
More bass
AGC adjustments
Bass EQ adjustments
Less stereo
Its a zipped file because the filesize is allmost half a mega byte , strange !
Marthijn de Rooij - P2GL 3.3 FM - 2024-10-28.zip [128.77 KiB]
Downloaded 408 times
PostPosted: Wed Dec 18, 2024 6:46 pm
Upgrades
tried to make the sound clean
Check the streams for audio
Marthijn de Rooij - P2GL 3.8 FM - 2024-12-18.zip [120.13 KiB]
Downloaded 278 times
PostPosted: Thu Dec 19, 2024 5:56 pm
Enabled Bass Boost and set its strength to 1.5.
Enabled Bass Clipper and Bass EQ.
Enabled Multiband Compression and increased gain for Bands 3 and 4 (mid-range).
Enabled Equalizer and boosted midrange Bands 3 and 4 for vocal clarity.
Enabled Stereo Expansion and set its strength to 1.2.
Enabled Limiter and set its strength to 0.8.
Marthijn_de_RooiEnhanced Bass.zip [118.27 KiB]
Downloaded 335 times
Downloaded 341 times
PostPosted: Sat Feb 22, 2025 5:45 pm
New update Plus MPX streaming via the FLAC codec @ 192KHZ test
YES lossless MPX streaming !
Adjusted a lot of setting in the MB compressors , especially higher knees for somewhat softer sounds.
The 2nd MB which is just a MB clipper is driven somewhat harder.
Still the low response dives somewhat when high frequencies become loud.
This can be caused by the setting for inter-modulation distortion in the advanced clipper but i want to retain the highs somewhat.
The MPX streaming is 16Bit 192 KHZ flac streaming
Just play the stream and put the output in your FM transmitter
MPX streaming test here :
MP3 stream
Marthijn de Rooij - P2GL 3B.zip [116.37 KiB]
Downloaded 291 times
PostPosted: Wed Apr 09, 2025 6:24 pm
Next preset is here
Adjusted AGC settings
Adjusted releasetimes in MB 1
Adjusted final clipper
Marthijn de Rooij - P2GL 4 FM - 2025-04-09.zip [100.2 KiB]
Downloaded 191 times
PostPosted: Sun Apr 27, 2025 5:07 pm
Update.
Added 8 band Auto EQ on the same crossover freqs as the first MB, also the same filter steepness
Better and more consistent (Sub ) bass response and more control over those loud high hats and cymbals and high hissing whoosssssssssh sssssssounds.
Lowered ratios for the highs and mids in the fist MB for less distortion.
Adjusted detection mode in MB2 to "adaptive but without....." instead of analogue.
Adjusted band coupling for more consistency ( band 2-3 and 3-4 )
Adjusted De- esser setting is in the Adv clipper because of auto EQ
And a lot of minor things
Marthijn de Rooij - P2GL4AEQ.zip [119.43 KiB]
Downloaded 222 times
