PostPosted: Fri Mar 04, 2011 8:31 am
Hello to all! My first post.. :)
So I have a question.
Is it posible to sound like this radiostation with stereotool?
http://www.radioseven.se
It is heavy processed but in a nice way - it has very controlled top and a lot of THE bass...
Thank you for your suggestions...
bets regards, David
PostPosted: Tue Mar 08, 2011 8:32 pm
Hi davidmb,
That station have very similar sound to my preset that i working on...
It;s not over yet!
You can check here.
just wait to come this type of music
PostPosted: Tue Mar 15, 2011 6:57 pm
Hey Bojcha!
I like your preset.
Is it made for webcasting or FM?
Would you like to share it with me so I can test it on my stream?
Thaks and best regards,
David
PostPosted: Tue Mar 15, 2011 8:18 pm
It's not like "seven", mostly because ST just can't have that much compression like most processor (pre/post MB and MB), which sometimes is good and sometimes not.
Anyway, i am testing preset only on stream currently.. It's close to be done (mostly waiting Hans to see what he will do with HPF)
For FM i'll need to do separate testing.
I'll post Preset soon. Both stream and FM.
PostPosted: Thu Apr 14, 2011 12:57 am
Install & Use Breakaway ;)
PostPosted: Fri Apr 21, 2017 9:38 pm
Radioseven was shut down today after 18 years of broadcasting. :cry: R.I.P.
https://www.facebook.com/radioseven/pos ... 0815179658
