 Post subject: FM Low Pass Filter
PostPosted: Wed Jul 31, 2024 12:02 pm
Low Pass Filter under the FM Output setting when checked, seems to amplify signal and distort? Am I missing something? I thought it was suppose to roll off the higher frequencies and not add any gain to the audio.
 Post subject: Re: FM Low Pass Filter
PostPosted: Wed Jul 31, 2024 6:31 pm
Hello,
Yes, that's what it should do. Can you send me your full settings (the .ini file - assuming that you're on Windows you can find it under C:\Users\username\stereo_tool.ini or something similar, depending on the exact version that you're using). I can't thnk of anything that could cause this, and I haven't heard of it before. So I hope that I can reproduce it with the .ini file.
PostPosted: Wed Jul 31, 2024 7:06 pm
Hello,
Here ya go. Thanks for the help! To prelude, I'm not running the pre emphasis because there is already one built into my EDM Transmitter.
Here is the link to the file you requested: https://drive.google.com/file/d/14EktSe ... sp=sharing
