 Post subject: Mono To Stereo
PostPosted: Mon Jun 24, 2024 1:07 am
hi which settings i need on stereo tool to hear only the audio signal on the right and left? the source is a mono signal. i can create a stereo field but. i really dont know how i get it on the headphones to the sides. i tried everything. i tried already the fake stereo but the signal is not on both sides the same i tried 10-15 ms but dont works really well. any ideas?
i also dont have any phase. i can create 1 phase with the phase shift but the other phase i dont know how i shall create the second one. the stereo reverb isnt also not bad to create a stereo field but its to small. i dont get to the right and lift side. greetings paul
 Post subject: Re: Mono To Stereo
PostPosted: Mon Jun 24, 2024 1:11 am
hi which settings i need on stereo tool to hear only the audio signal on the right and left? the source is a mono signal. i can create a stereo field but. i really dont know how i get it on the headphones to the sides. i tried everything. i tried already the fake stereo but the signal is not on both sides the same i tried 10-15 ms but dont works really well. any ideas? tx for 4 help greetings paul
In standalone, go to Audio I/O, under miscellaneous there is menu, only left, only right, mono, stereo.. etc
PostPosted: Mon Jun 24, 2024 1:15 am
ehm i have it as a vst in my daw. i dont have the stand alone version
https://ibb.co/qYMzch9
PostPosted: Mon Jun 24, 2024 1:54 am
Ahh, strange, idk why that is not there. There is other things that are not related to VST usage, but that one is not there.
PostPosted: Mon Jun 24, 2024 1:59 am
I think the only way to do this with the plugin is sorta hacky. You have to right click the balance slider on the Low Level Input Correction and type a value -100 for left, or +100 for right. The GUI only limits it to +-3dB, and the maximum is +-100.
PostPosted: Mon Jun 24, 2024 2:48 am
okay i tried it. y it creates only a left or right signal. need left and right. i dont know i used all slides in this vst. the closest one is fake stereo but.....left and right is not the same...i mean nobody will notice this...but i notice this xD
PostPosted: Mon Jun 24, 2024 3:30 am
Ah, my apologies. I misunderstood what you were trying to accomplish.
For this, I think you want to do what I said then go to Processing, Stereo, Stereo Image, then in the Dynamic Effects section, you want expand > and put everything to the left. That's 0% phase amplification, 0% image width amplification, and -100% stereo sounds. This will take a stereo signal, keep only one channel, then output it to both channels.
PostPosted: Mon Jun 24, 2024 7:31 am
like this? https://ibb.co/pxx1sSy i dont know excatly what i did:>
PostPosted: Mon Jun 24, 2024 8:00 am
tx bro for help...but is it mono compatible?
looks like on mono they cancel out
I went to the ophthalmologist about something like this. Either the equipment doesn't fit or I really have ear problems. But the ear doctor said everything was okay. and he was not drunkxD
very very strange
PostPosted: Mon Jun 24, 2024 9:11 am
Ah, you changed the phase shift. That needs to be back in the center.
