 Post subject: Question: Run as service
PostPosted: Thu May 02, 2024 1:59 pm
Hello Friends,
In programs i see Stereo Tool “ Run as Service “.
That means it will install as a service running in the background. After install how to login into it and do my config ?
What are the pros running it as a service?
Cpu load?
Best regards
PostPosted: Thu May 02, 2024 2:15 pm
I use the service on my laptop to keep Stereo Tool processing for whoever logs in. AFAIK, it's the only way to get ST running without logging into Windows. Handy in case of power loss, I presume.
To configure Stereo Tool, one would use the Web Interface, as found at the bottom of the main Application Settings page.
PostPosted: Thu May 02, 2024 2:41 pm
Thanks you froend,
Yes dig further and saw the web configuration section.
Regards
