PostPosted: Tue Mar 12, 2024 5:55 pm
Hello, I purchased Stereo Tool V8.54 on April 5, 2018.
License type: Basic + Declipper
Licensed to: Thomas R Casten
I was using it with MusicBee, but switched my player to JRiver Media player.
JRiver will not install the Stereo Tool plugin.
Error.
Failed to install plugin.
Any suggestions?
Thanks!
PostPosted: Tue Mar 12, 2024 6:14 pm
I kept trying. Finally, I downloaded the latest version, 10.21.
I registered it and it's working.
*** I'm doing this on a test computer.
Now I need to install it and license it on the computer I use for daily music.
Q: Do I need to somehow "unregister" it on this test computer?
Thank you.
PostPosted: Tue Mar 12, 2024 10:19 pm
Hi. Yes, the latest versions of Stereo Tool are always recommended for the best compatibility and functionality. Glad 10.21 works.
You should just be able to license the new instance on the other computer with your key without doing anything special on the old one.
PostPosted: Wed Mar 13, 2024 4:27 am
Thank you! It's working just great!
