Post new topic  Reply to topic  [ 35 posts ]  Go to page 1 2 3 4 Next
 Post subject: Dumans HD 2.9 Adaptive
PostPosted: Fri Mar 01, 2024 10:43 pm
Hi. A new update using V.10.21 new compressor adaptive settings
Changes made
- New AGC.
- 20% less CPU load from previous versions using only EQ & Auto EQ for tonal shaping.
- Using 1 compressor & WB in adaptive mode.
- Loudness level is around -6lufs and output post amp set to -0.3db
The overall result sounds very balanced between density and open sound
and of course great job done by the ST development team.
I hope you enjoy it. Always good to have you feedback and comments.
Dumans_HD_2.0_Adaptive.zip [108.98 KiB]
Downloaded 1094 times
PostPosted: Sun Mar 03, 2024 1:36 pm
I really like this one. You can hear it here.
PostPosted: Wed Mar 13, 2024 7:31 am
Hi. Just made a new one with 2 compressors and some tweaks
for tonal balance control.This one is more heavy in the processing
part.The output is at -6lufs and -0.3db tp. Keep in mind to have input
level around 80%
Always good to have your comments and feedback.
Dumans_HD_2.1.zip [111.12 KiB]
Downloaded 585 times
PostPosted: Wed Mar 13, 2024 10:00 am
the trebles seems to be a bit high, especially in treble-heavy soungs where it amplifies them even more. Otherwise everything sounds quite smooth and balanced. :)
PostPosted: Wed Mar 13, 2024 2:37 pm
Hi. I must admit i deliberately set high frequencies boosted because of testing hi-res content (flac) in a lossy streaming format (aac). The goal is to have more intense and crisp high freq without distortion and imho it handles it very well. Fyi you can listen this stream here:https://zeno.fm/radio/ianthos-radio/
PostPosted: Sun Mar 17, 2024 2:52 pm
Version 2.1 is too heavy for my computer. It is I3 a fourth generation i3 with 4 gigabytes of RAM.
PostPosted: Mon Mar 18, 2024 7:46 am
True but you can tweak it. Im using i5 2nd gen 4gb of ram
PostPosted: Mon Mar 18, 2024 7:56 am
Uploading something more solid and balanced as v2.1 was more for testing.
As always its good to have your comments and feedback.
Dumans_HD_2.2.zip [110.58 KiB]
Downloaded 596 times
PostPosted: Mon Mar 18, 2024 12:30 pm
Greetings duman king of concert versions of presets and part tones. In my opinion, what I hear through my headphones hd 400 pro is the best preset you made is 2.0 for adaptive. It just sounds aggressively concert in your style. The latter has somehow cut off the bass and pronounced mid-tones. I'm telling you this as I hear it because I, who have been blind since birth with screen readers, cannot read graphic displays, but I have some possibilities through the web interface that I can do and that I know how to do. What I hear is your result that 2.0 is best set up for music. I will contact you privately and give you more details. Please follow private messages.
PostPosted: Tue Mar 19, 2024 10:11 am
Version 2.0 is the best. Last night I tried version 2.2 and I was not satisfied. The middle tones are too strong and there is some slight distortion in the sound. I'm using VST2 64 bit with RadioBoss software. Stereo tool version is 10.21.
