Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Mon Feb 12, 2024 11:38 pm
Tested with Stereo Tool 10.21/ 10.30 (I'll try to update it if there are major changes in ST that affect the sound of the preset)
I would advise to also load the Repair settings.
Input level best at around -6 dB.
Extra drive Composite clipper: +1.00 dB.
Multiple RDS RadioTexts
This is a way to have more changing RDS RadioTexts than the standard A and B ones, with the help of taskt, a free automation program.
I have made a simple example and instructions to set it up in the zip attached.
File comment: Prismic Hot (ST 10.30)
Prismic Hot (ST 10.30).zip [32.22 KiB]
Downloaded 883 times
File comment: Prismic Hot v1.5
Prismic Hot v1.5.zip [32.15 KiB]
Downloaded 799 times
File comment: RDS Radio Texts
RDS RadioTexts.zip [2.69 KiB]
Downloaded 698 times
 Post subject: Re: Prismic Hot (FM)
PostPosted: Tue Feb 13, 2024 7:22 pm
These is a decent preset only thing that needs to be changed is the treble is a little high
Thanks, maybe I should have mentioned (as I did with the House One XL preset): Might be too much highs for other then FM broadcast, you just can lower them a bit in the EQ.
PostPosted: Wed Feb 14, 2024 5:20 am
Sounds great. I'd say trebles are only too high on treble-heavy songs. I experimented with highs in auto eq set to -12 and the de-esser at around -10, sounds better than with lowering highs in the EQ. :)
PostPosted: Wed Feb 14, 2024 2:48 pm
Thanks!
If you want could you pm me a preset with only the settings of the auto eq and de-esser?
I'm testing an update to the preset at the moment, maybe I can ad them, so people who want to use the preset for other then FM broadcast can turn those on.
PostPosted: Wed Feb 14, 2024 2:59 pm
Done. :)
PostPosted: Fri Feb 16, 2024 5:33 pm
v1.1 update and a way to have multiple RDS RadioTexts in first post.
PostPosted: Sat Mar 02, 2024 2:08 am
Preset completely redone, v1.2 update in first post.
Depending on the frequency response of your setup/transmitter you might try playing a bit with the EQ by lowering/raising the first Gain (30 Hz) or the HF Gain.
PostPosted: Sun Mar 03, 2024 4:04 am
v1.3 final in first post, thanks for the comments/contributions.
PostPosted: Fri Mar 08, 2024 11:32 pm
v1.4 Final II up, many changes, sounds much better imho and also should stay within limits much better.
Also has the Noise gate and Speech detection (as far as I can test) set up and activated.
This preset is actually tested on a professional FM transmitter (Suono ESVB) connected via the RF Monitor Out (Test) to a 14bit SDR (RSPduo).
Software used: Youlean Loudness Meter 2 Pro, Orban Loudness Meter, MpxTool and RDS Spy.
Listened to via a Traktor Kontrol S4 (24bit, 96khz soundcard), Beyer Dynamic DT 770 Pro LE headphones and M-Audio BX5 monitor speakers.
PostPosted: Tue Mar 12, 2024 12:57 am
The final of the finals in the first post, I would advise to use this one instead of v1.4 because the phase delay caused some distortion in the bass and should have been off.
