PostPosted: Thu Feb 01, 2024 8:02 pm
macOS Sonoma 14.3 using 10.20 (2.4 GHz 8-Core Intel Core i9, graphis: AMD Radeon Pro 5500M 8 GB).
All the scopes are disabled with the message "Disabled by zoom factor":
But I don't have a zoom factor on my monitor (I'm using it natively). It also says this on the Retina display built into my MacBook Pro. I've not been able to get the I/O scopes to work.
Interestingly, things like DeLossifier and Absolute Highs work fine:
Anybody had this issue or know how to fix it?
PostPosted: Fri Feb 02, 2024 2:11 am
Use mouse wheel :)
PostPosted: Fri Feb 02, 2024 5:28 am
Yes. Hover the mouse wheel over the scopes and scroll. It must have zoomed in or out completely at some point.
The DPI scaling of one's monitor is something completely different.
