 Post subject: License Move and upgrade
PostPosted: Mon Nov 20, 2023 5:12 pm
Hello. Just Bought StereoTools FM Professional License with some add ons and installed in a temporary computer to try out configuration. Can I deactivate the license in this computer and move it to the permantent PC i will use for it? What is the procedure?
Also, can the StereoTools FM Pro license be upgraded to ST-Enterprise?
Thanks,
PostPosted: Tue Nov 21, 2023 5:48 pm
1. Yes, just stop using the license on your old pc and start using it on the new one, that's all. To make sure you can remove the "Registration key=" line from C:\Users\username\stereo_tool.ini (or just remove the whole file if you don't care about your settings).
2. Yes, by paying the difference in price. We don't have an automated way of doing that, so please send an email to support@thimeo.com . (Upgrading is only useful if you need Enterprise-specific features (watermarking, better password protecton) or if you're going to run multiple instances on the same system.)
