PostPosted: Thu Oct 19, 2023 1:03 am
This might be a stupid question and I apologize if it is: I am trying to VST plugin, but can the standalone version of Stereo Tool utilize and process System Audio? I'm on a Mac, and I'm used to programs like Audio Hijack which capture sound. However I can't seem to figure out how to just play music and have the Stereo Tool process it.
PostPosted: Thu Oct 19, 2023 1:11 am
Yes, I believe it can. However, I cannot help you personally as I am on Windows. You might have some luck using ChatGPT as an aid if nobody happens across who uses Mac OS.
In Windows you need to download a virtual cable/soundcard to send system audio to, which Stereo Tool then takes, processes, and outputs to your selected speakers. I hear CoreAudio is a little less messy than Windows audio APIs, so you might be able to do this without downloading anything.
Best of Luck!
PostPosted: Thu Oct 19, 2023 6:37 pm
One word: Loopback
https://rogueamoeba.com/loopback/
MrDonT
