PostPosted: Wed Sep 13, 2023 7:08 am
If I start the 10.10 shared library Stereo Tool with Liquidsoap, liquidsoap stops with the following error message:
At streamtranscoder.liq, line 12, char 2-68:
s=track.audio.stereotool(%argsof(track.audio.stereotool[!id]),audio)let replaces s=source(id=id,{audio=(s:pcm),metadata=metadata,track_marks=track_marks})s
Error 14: Uncaught runtime error:
type: invalid,
message: "Invalid stereotool library",
stack: at streamtranscoder.liq, line 12, char 2-68,
at streamtranscoder.liq, line 35, char 2-202
There is no such problem with the previous version.
The old one has libStereoTool_64.so, the new one has libStereoTool_intel64.so. I renamed this accordingly.
PostPosted: Sun Jun 01, 2025 8:05 am
The same problem resurfaced in Debian 13 (trixie). It is probably also affected in Ubuntu 25.04.
PostPosted: Fri Sep 19, 2025 6:05 pm
I'm guessing this is not an issue anymore, but what versions of libStereoTool did you test that on?
No problem since 10.51 on debian 13 at least.
