PostPosted: Tue Aug 29, 2023 8:51 pm
Hi all,
There's a lot of tweaks you can do so and I'm not sure how to get a clean sound as possible.
I want ST to work only as a leveler or minimum processing.
Does anyone have some tips or a preset?
PostPosted: Wed Aug 30, 2023 5:34 am
Hi. The AGC's default settings may be a starting place for what you want. Just enable it, raise the Drive how much you want it to adjust, and lower the Target Level til you find the right loudness. You might even want to try out the 2-band mode, which has better bass consistency but starts changing the sound ever so slightly the more bands you add.
Hope this helps.
PostPosted: Fri Sep 01, 2023 9:11 pm
I just it on my stream > JohnnyFM
I download this version early : Array Low Bit Rate DAB Plus and tweak it a little bit i used dx2000 usb with proppfrexx and stereotool.
Stream test : (website soon online).
http://mscp2.live-streams.nl:8300/radio
https://mscp2.live-streams.nl:8302/radio
Greets
From the dutch. i try something.
JohnnyFM v.1.0.sts [91.37 KiB]
Downloaded 237 times
PostPosted: Fri Sep 01, 2023 9:13 pm
version 1.1
JohnnyFM v.1.1.sts [91.39 KiB]
Downloaded 257 times
PostPosted: Mon Sep 04, 2023 3:27 am
Here's my minimal preset. Hope this works for you.
Update should be more constant in loudness.
Updated Gate may cause problems with low level music
minpreset.sts [173.92 KiB]
Downloaded 280 times
Fidelity over loudness
