Seems no one has a solution...
I switched to using a plain UDP transport. This is how I did it:
On the pi running mpd:
ffmpeg -nostdin -loglevel quiet -i http://ip6-localhost:8001 -c:a libfdk_aac -b:a 448k -profile:a aac_low -f adts udp://nuc:4002?pkt_size=1452
And on the NUC running ST:
Set
udp://@:4002
as the stream URL
Then made sure syncing was turned on for the inputs and both the normal and FM outputs.
So far so good. Will report back if it lags badly.
KPSK-FM 100.7 The Cube
We're the station for LA's cubers!
