 Post subject: BBC Radio 1... (ish?)
PostPosted: Wed Jul 26, 2023 11:28 pm
Have a try, I know its not exactly the same but could do for now.
BBC Radio 1 ...ish version2.sts [174.73 KiB]
Downloaded 1653 times
BBC Radio 1 ...ish..sts [174.83 KiB]
Downloaded 2612 times
PostPosted: Mon Jul 31, 2023 6:02 pm
This is great! Thanks for sharing. Really natural, musical sound. Which seems quite hard to find with ST.
PostPosted: Tue Aug 08, 2023 8:54 pm
Works well with the throwbacks too.
PostPosted: Wed Aug 09, 2023 12:35 am
What I really like here is that there is no tone pumping, but what I needed to do, as I hear with the hd sennheiser 400 pro headphones, is to boost the middle tones, which are the frequencies that go from 700 h to 1000. These lower frequencies of 500 are good. These are the ones that go towards the deep tones from the midrange. I would fix this myself, but unfortunately, since I am completely blind, some things in the stereo tool still cannot be done in our screen readers. Basically, if you're going to make these corrections, let me know and I'll listen to each of your presets.
greetings from Sarajevo
Edinquote="DS Radio" post_id=74139 time=1690406921 user_id=37660]
[/quote]
PostPosted: Sat Aug 12, 2023 10:43 pm
It's a great preset. I like. Everything is loud and nothing is too loud.
PostPosted: Sun Aug 13, 2023 12:43 am
Thanks for all your comments, It'll still need work but I'm happy that it works for you all just now, even if just a temporary preset :D
PostPosted: Thu Sep 07, 2023 8:50 pm
With user-made presents like these, does anyone sometimes get a loud click or buzz sound when switching between them, and then all sound cuts out on my computer (MacBook Pro) until I restart? I'm using Loopback to 'wire in' Stereo Tool, rather than use an external audio interface.
PostPosted: Thu Apr 04, 2024 3:21 pm
I like this pre-set it's frequency response is way I like to have it.
PostPosted: Thu Apr 04, 2024 3:22 pm
Version 2 Available.
PostPosted: Thu Aug 29, 2024 12:12 am
Still working on it... for now try out 'Radio X attemPt' posted recently...
