 Post subject: Latency problems?
PostPosted: Sun Jun 04, 2023 7:49 pm
unfortunately I noticed that there might be a latency problem, which would explain why I hear sometimes clicks and pops in the livestream :(
Unfortunately I can't use LatencyMon on my Windows Server 2022 (Remote) in the free version.
Percentage of time in processing about 45 %, GUI Display 10 - 20 % - is this good or bad?
I disabled many devices in the device manager, also deactivated the CPU throttling settings via gpedit.msc. Power mode set to high.
Using 4 CPU cores, optimized for latency, 4096 samples, parallel threads 2.
Main1: 2, 2nd1: 2
Main2: 1, 2nd2: 0
Has anyone an idea what else I can do? Would you recommend to set the CPU priority to "realtime" instead of "high" for RadioBoss (in which runs ST DSP-Plugin)? In the Task-Manager there is sometimes a green leaf symbol right to "RadioBoss" (UWB) - is this normal?
 Post subject: Re: Latency problems?
PostPosted: Fri Jun 09, 2023 10:50 pm
sometimes clicks
Increase buffer
PostPosted: Fri Jun 09, 2023 11:12 pm
Where can I do that in StereoTool?
The Percentage of time gui display is now at 0,1 % - is this good or bad?
Percentage of time in processing around 50 %
