PostPosted: Wed Jan 18, 2023 5:34 pm
"Goniometer After" long longer shows the post-processed signal, it's identical to the "Before" plot.
It broken sometime between 9.83 and 9.91.
Also, can it be classed a bug that it's 45° inclined to the right and not vertically aligned? Or should I create a "Wish list" post? :-)
Martyn.
PostPosted: Thu Jan 19, 2023 9:23 am
Confirmed, I don't like the 45° tilted meter either.
In the new GUI beta, the output differs from the input, so this might be fixed already somewhere.
PostPosted: Thu Jan 19, 2023 11:36 am
Hi! I think if you put this as feedback in the new GUI beta feedback thread, you will sooner get a response as to why this cannot happen or if it will be implemented from the developer of the new GUI, t.j.evers: viewtopic.php?f=14&t=32703
The Wish List subforum eventually gets gotten to as well, but it seems to usually happen when a release comes out of beta, which is less often than the beta threads being updated.
PostPosted: Thu Jan 19, 2023 11:43 am
Thanks both.
