PostPosted: Mon Dec 26, 2022 9:34 am
In 9.92 when auto-starting with Windows ST boots OK, but goes into bypass mode. With 9.91 it booted into the last used preset. Or is there a new setting I'm overlooking?
PostPosted: Mon Dec 26, 2022 11:24 am
Weird. Is your stereotool.ini in read-only by chance? Does it still do this in the ST 10 betas (old or new GUI)?
PostPosted: Wed Jan 18, 2023 4:23 pm
Sorry for replying this late. Are you sure that it's in bypass mode? That must be set explicitly (it's a checkbox that must be enabled), so I can't explain that at all. If it just doesn't display the preset name, that would make sense.
