PostPosted: Mon Sep 26, 2022 8:55 pm
It's been a while since I had something I felt was worth getting opinions on. What are people's thoughts on this preset?
This preset is mainly about the MB-AGC in 3-band mode and Bass effects. I realize the bass is probably too much for most people, but it sounds great on my non-monitor speakers.
Requires Declipper and Advanced Dynamics license. Approx -14LUFS
Made using new GUI, but it should be fine in old. Beta 9.92 053
Ty02d.sts [192.61 KiB]
Downloaded 547 times
PostPosted: Wed Sep 28, 2022 7:45 pm
I tried this preset. However, it has the same problem as all the presets in Stereo Tool that have strong bass. On speakers that have strong bass, everything is ok. However, the bass drum can be heard too much on speakers that have less pronounced bass.
PostPosted: Wed Sep 28, 2022 10:25 pm
Thanks for the feedback. Do you think it would benefit from the Bass Clipper on smaller speakers? Fewer bass filters like exciter or immersive bass? Or what about reducing the level of the lowest band in the AGC?
PostPosted: Wed Sep 28, 2022 11:32 pm
I hardly understand the settings, but most of the presets with strong bass in Stereotool have this problem.
PostPosted: Thu Sep 29, 2022 2:29 am
For me to make it little more "real" i needed to up middle band by 6dB. But good try on that AGC.
PostPosted: Thu Sep 29, 2022 11:33 am
I'll take this into consideration if I update it. It does indeed sound more natural, and I forgot about the Ariane recommendation for something like band 1 being 6db less than band 2, and band 4 being 6dB less than band 3.
For three bands, that would make the center band +6db compared to the other two, rather than the flat way I had it set up initially.
Thanks!
PostPosted: Thu Sep 29, 2022 5:11 pm
To be more precize middle band by 4.5-5dB. From -3 to +2.
