PostPosted: Sat Sep 10, 2022 5:36 pm
Hello!
It is still a mystery how one would configure Stereo Tool's AES67 input since documentation does not mention it and most of the tooltips are missing currently.
Anyone succeeded? How? What is subrange, what is channel? Is Stereo Tool advertising itself via SDP? :roll:
PostPosted: Wed Sep 28, 2022 7:27 pm
Yes I would like to also know how this can be configured, absolutely no documentation for this area of the application. Any help would be welcomed.
PostPosted: Fri Oct 21, 2022 5:26 pm
Okay, I figured it out!
When you choose Generic AES67 input, you need to type your subrange and your channel. Subrange is the second octet of the multicast address of your AES67 stream. Channel is the fourth (last) octet of the multicast address of your AES67 stream.
Then, sound should just start playing. There isn't any other indication of success.
And, the discovery stuff doesn't work. There isn't a list generated under "Device" even though Ravenna and AES67 streams are announced on the network.
So, if you don't know your AES67 stream address[es], open Wireshark and take a look from there :)
Short guide: multicast address of your AES67 stream: 239.<subrange>.0.<channel>
