PostPosted: Sun Aug 21, 2022 1:35 pm
Hi, My setting is Radio automation with VAC Line 1 and Sterotool VAC line 1 in I use VAC 2 for the stream from stereotool to the stream program. I've been using stereotool in combination with micrompx for a while, so nothing from FM or the like is on in sterotool. I use the Normal out for the stream. What should I choose here at signal Selection? I can pack VAC 1 line into the streamer but then I have no processing.
