 Post subject: Compector - Ver 1
PostPosted: Sat Jul 16, 2022 3:36 pm
Hello Gents,
Here is the new preset ive been working on.
This one is loud.
Based on Previous MX8600 preset previously posted
Removed Multiband clipping and only using Limiting
Removed Auto-EQ
Tweaked Release hold times
You can season and spice to suit your needs
Enjoy
Comments welcome
Compector - ver 1.0.sts [135.45 KiB]
Downloaded 670 times
 Post subject: Re: Compector - Ver 1
PostPosted: Tue Jul 19, 2022 1:33 pm
Hi good morning. Very good preset. I tried it for MPX output, could you tell me how to lower the bass, the noisy sounds so that it is ready?
PostPosted: Tue Jul 19, 2022 2:50 pm
Pull the TrueBass Strength back to suit your tastes.
I have reference speakers so it suits flat response speakers, If you have a set of gaming speakers its going to sound a big bassy
PostPosted: Tue Jul 19, 2022 4:07 pm
It sounds very good, but in the car stereos with some songs the bass comes out very strong, could you tell me where that option is so I can make the adjustment and tell you if I can leave it full?
PostPosted: Tue Jul 19, 2022 4:11 pm
Try this preset
I have pulled the bass back.
Compector - ver 1.1 - Less Bass.sts [135.45 KiB]
Downloaded 529 times
PostPosted: Wed Jul 20, 2022 12:33 pm
I am liking this preset.
A couple of points. I hear slight pumping on the AGC in some songs.
I also hear distortion in speech.
PostPosted: Wed Jul 20, 2022 12:37 pm
I am hearing distortion in speech too.
PostPosted: Wed Jul 20, 2022 1:02 pm
First: is not loud and the pumping and distortion is very obvious and annoying, you need to fix that.
PD: and need to enable the Hard Limit output and Bandpass filter for FM
https://fmfeeling.com
PostPosted: Wed Jul 20, 2022 5:22 pm
You will note the version... 1
and lastly.. not all preset are made for FM.. Turn that on yourself should you require it
PostPosted: Wed Jul 27, 2022 4:33 pm
Righteo Gents,
I did some changes to the AGC and other tweaks.
Give this one a whirl.
Compector - ver 1.3.sts [135.52 KiB]
Downloaded 605 times
