 Post subject: Upgrade Error
PostPosted: Mon Jun 13, 2022 2:54 am
In trying to upgrade from v9.83 to 9.91 on CentOS 7 running Rivendell and Stereo Tool through Jackd to an ESI soundcard, I get the following error:
/usr/bin/stereo_tool_gui_jack_64: error while loading shared libraries: libmvec.so.1: cannot open shared object file: No such file or directory
Is there a fix for this? No problems when I go back to 9.83.
--Chuck
 Post subject: Re: Upgrade Error
PostPosted: Mon Jun 13, 2022 9:38 am
--Chuck
that has something to do with libc which should have libmvec included i think.
it might be that the version of libc for centos 7 doesn't have a libc with libmvec?
you might need a newer version of centos for this.
PostPosted: Thu Jun 16, 2022 4:40 am
Thanks! It is going to be a good while before we upgrade, so I guess we're stuck on 9.83 until then.
--Chuck
PostPosted: Thu Jun 16, 2022 5:01 am
--Chuck
You might bring it up in a DM with Hans or raise the issue in the beta thread. I'm sure some kind of dependency was updated which inadvertently broke something. At least to find out if it's something to be stuck with.
