 Post subject: Stereo Tool 9.91
PostPosted: Sat Jun 11, 2022 12:52 am
Stereo Tool 9.91 has been released! This is mainly a bugfix release, with a few small new features. You can get it at https://thimeo.com/
Changes:
  • ITU1770 meter now also shows multiple time intervals (Immediate, 3, 10 and 30 seconds).
  • GUI: Disabled Lowpass slider if it's inactive (no streaming output, and FM/AM lowpass filtering is in use).
  • Workaround added for OBS (Stereo Tool running as a plugin in OBS could cause it to crash after loading/saving presets).
  • Bug fix: Plugin versions tried to open an input sound card in version 9.90. This could cause an error to be reported.
  • Bug fix: Delossifier highs behavior was inverted in version 9.90 (what happened was the opposite of what the setting said).
  • Bug fix: Window title wasn't always correctly set in version 9.90.
  • Bug fix: Bass Exciter didn't work properly with Delossifier Spectral Hole Filler enabled.
  • Bug fix: DeReverb was not disabled by pressing "Disable unlicensed features".
  • Bug fix: Linux version: The file save dialog could write 1 byte outside of memory (doesn't seem to have caused any problems).
  • Optimized opening of multiple web interfaces (that could cause some unrelated things to be restarted).
  • Updated presets.
  • Linux Enterprise build added.
  • macOS Enterprise build added (without native GUI for now, use the web GUI instead).
  • WatchCat: Bug fix: Stereo Tool license was sometimes not accepted in version 2.0.5.
  • MicroMPX: Added description field for each encoder and decoder, for stations with many decoders.
  • MicroMPX encoder library: Now returns sample time stamps, for external SFN support.
  • MicroMPX decoder library: Solved channel separation issue in optimized MPX demodulator (this does not affect anyone, as nobody was using it yet).
