 Post subject: Bug in Thimeo WatchCat
PostPosted: Sat May 21, 2022 5:39 pm
Attaching bug report in Thimeo WatchCat when applying a preset.
Please check the link:
https://ericade.radio/files/Bugreport-T ... tchcat.pdf
PostPosted: Thu May 26, 2022 4:25 pm
Anyone there?
PostPosted: Wed Jun 08, 2022 8:13 pm
Not too much to get this resolved then, I guess?
PostPosted: Thu Jun 09, 2022 11:39 am
Have you tried the beta version to see if the bug is resolved?
viewtopic.php?f=14&t=32702
If you find that the problem is there, please do report in that thread which is being actively monitored by the developers. If it's fixed, report that too :-)
Hope this helps.
PostPosted: Thu Jun 09, 2022 2:32 pm
Yes, what Radio Quack said. Also, it could help if you post a link to the preset itself.
PostPosted: Sat Jul 02, 2022 9:28 am
Here is a video demonstrating the problem after installing the latest StereoTool and Watchcat:
https://youtu.be/Zt5e37O1JP4
And here is the preset:
https://radio.ericade.net/files/WatchCat.sts
PostPosted: Sat Jul 02, 2022 10:52 am
Fixed!
See viewtopic.php?f=15&t=33057
