PostPosted: Tue Dec 09, 2008 4:01 pm
I have installed steretool on a windows 2003 Server
Winamp is running with muchFX
Sam Encoders is running
and Stereotool windows visible
To run sceduling i have running Proppfrexx ( http://radio42.com/proppfrexx/ )
The stereotool is starting normaly and running fine and the Trayicon is visible on startup.
also i can open the StereotoolWindow.
But when i want to hide it again, the whole system is stopping.
Throug a remote console i can reach the Server and i have to kill the whole winamp Prozzes befor i can work again normaly.
So conclude, all running well untill i try to open the Stereotoolwindow and close it
What might the problem be?
Greetings from Germany:
Andreas Duswald - Radio Lechtal
PostPosted: Tue Dec 09, 2008 5:31 pm
I have never heard of this problem before, so I need some extra info...
- Which Stereo Tool version are you using?
- Have you loaded all those DSP plugins in Winamp? If so, how did you do that (DSP Stacker?) Or are the others not DSP plugins?
- Can you check what happens if you load ONLY Stereo Tool as Winamp plugin? That way I know if the problem is triggered by those other plugins, or by Windows Server 2003. (I would guess that it's caused by Server 2003, but if that's the case I would have expected much more reports about this problem.)
- Does this always happen, or occasionally (I don't want you to keep trying it, but if it went fine sometimes too, I'd like to know...)
Thanks,
Hans
