PostPosted: Sat Apr 30, 2022 11:46 pm
yes i test it ...it sound's good...good job ...me i prefer more bass as you know the amplitude modulation is a part off this ..especially when your signal is traveling to long distance.. the highs frequencies i put the filter in 10khz sounds crispy... any way is a good try ...bravo....
PostPosted: Mon May 02, 2022 1:30 pm
Sounds like an Optimod AM to me :)
PostPosted: Mon May 02, 2022 9:13 pm
ok thanks ....i have done already all those things...i,m on air.....
PostPosted: Wed Sep 28, 2022 7:10 pm
hello again yes it souds good ...a question ..do you have on the advanced clipper of stereo tool??? if yes ...why???
PostPosted: Thu Sep 29, 2022 12:07 pm
The audio is then sent to the 'Singleband' processor which functions as the 9100's 'Safety clipper', which is a hard clipper on the 9100.
thats i,m asking you why you use the advance clipper........
PostPosted: Sun Oct 02, 2022 2:09 pm
yes ,,ok in analysed it looks better without advance clipper ...bcs in stereo tool the filters at least in latest versions are wrong in my opinion ...we have discuss this with Hans to make them more flat in 0dbv we have to wait,,,any way me i have take it out of order ....
thanks for the reply keep going now with 9200 or better with 9300 ouaou.....it will be fantastic,,,
PostPosted: Mon Jan 08, 2024 3:12 pm
Anyone still have this preset? I want to try it on my Part-15 AM Stereo Transmitter.
