PostPosted: Sun Apr 03, 2022 12:17 pm
Hi all
thought I would share this preset.
How I got it sounding like this was mostly trial & error, and determination to get my station sounding as good as I can.
I consider myself a perfectionist - most of the time I didn't know what on earth I was adjusting all I know was that at the end of it all I had a smooth, crisp clear sound.
At times, audio can get a bit distorted but not sure if that's due to the ST settings, or my RadioBoss app which I use, but overall I think it sounds excellent.
I use this to feed both my low power FM transmitter, and live stream.
Try and out, and let me know what you think.
Thanks
Breathe Radio.sts [173.16 KiB]
Downloaded 604 times
PostPosted: Sat Apr 09, 2022 5:43 pm
TBH, Sounds muddy
What kind of speakers/headphones are you using?
