 Post subject: DLL Mismatch Help
PostPosted: Sat Mar 26, 2022 5:46 pm
I'm trying to turn on the Output stream on a trial version of the software before I buy. I keep getting an error every time I try to turn it on. I've tried various Output stream options, they all seem to fail. How can I tell what DLL is the issue? The error message says: An exception occurred in: AudioPlayer/Streaming:DLL version mismatch (an unexpected DLL version was found). This could mean that a DLL in your host application collides with one in Stereo Tool. Address 0x7682b922 of C:\WINDOWS\System32\KERNELBASE.DLL Offset-info: 0x1321c9e3, version 9.83.
I am running Stereo Tool as a DSP plug-in to Media Monkey Version 4.
Thanks,
Glenn
 Post subject: Re: DLL Mismatch Help
PostPosted: Sat Mar 26, 2022 9:47 pm
I figured it out - I copied all the Stereo Tool .DLL files from the plugin directory to the root directory which included a new lame encoder.
PostPosted: Wed Mar 30, 2022 10:39 pm
Ah, so did you overwrite an existing file there?
