PostPosted: Fri Mar 11, 2022 1:51 pm
I'm using the Linux 64-bit command line version of Stereo Tool. I noticed that sometimes when there is some problem, a file called "C:\temp\StereoTool_Exceptions_Log.txt" is written to the directory from which i started Stereo Tool.
Not a huge problem, but it might be a good idea to use another path (/tmp/StereoTool_Exceptions_Log.txt or something similar?) on Unix like platforms like Linux and macOs for this.
PostPosted: Fri Oct 14, 2022 4:09 pm
Ah, whoops. I've changed it to write it to the active directory instead.
