PostPosted: Mon Oct 25, 2021 2:29 pm
Hi Forum,
I'm running a test setup, feeding µMPX from Windows ST 9.82 to a RPi Decoder over a VPN connection. The decoder sounds fine but shows constant
2021-10-25 13:26:54.643 warning: Pilot phase shift detected (0.132259).
2021-10-25 13:26:54.665 warning: Pilot phase shift detected (0.235963).
2021-10-25 13:26:54.673 warning: Pilot phase shift detected (0.178364).
2021-10-25 13:26:54.717 warning: Pilot phase shift detected (0.115455).
2021-10-25 13:26:54.730 warning: Pilot phase shift detected (-0.17188).
messages.
What can I do to fix this?
PostPosted: Mon Oct 25, 2021 3:06 pm
Are you using the built-in stereo/rds generator in Stereo Tool, or are you feeding it from an external RDS encoder?
PostPosted: Mon Oct 25, 2021 3:29 pm
It's the internal generator.
ST itself is driven by a PCI sound card using ASIO in / out.
PostPosted: Mon Oct 25, 2021 3:31 pm
Ah, and no RDS enabled yet.
And I noticed that µMPX decoder refused to decode anything as long as the stereo encoder was switched off. It was off as the current setup uses the transmitters inbuilt stereo coder. Of course that all shall change when testing is done.
PostPosted: Fri Oct 29, 2021 1:32 pm
This seems to be somehow related to the number of CPU cores in use. I'm searching for the cause now, will release a new version asap.
PostPosted: Fri Oct 29, 2021 3:12 pm
Found it, working on a fix now.
PostPosted: Sat Oct 30, 2021 11:25 am
Solution beta build:
viewtopic.php?f=14&t=31072
