PostPosted: Thu Aug 05, 2021 5:14 pm
Can't seem to blow up the ST screen, too small to read now.
Windows 10
Anyone?
Thanx
Robert
PostPosted: Thu Aug 05, 2021 5:20 pm
If you are on 2k display or more, yes, it's small. And you cannot unfortunately resize it. GUI is just like that.
Only thing you can try is to set different DPI compatibility for ST.
Right click on StereoTool.exe > properties > Compatibility > Change High DPI...
I am on 2K monitor and i also use Custom Scaling size in windows, 133, to match more to 1080p display.
PostPosted: Fri Aug 06, 2021 8:41 pm
thanx Bojcha, yes the only way seems to be to rescale the screen, I'm on 3840x2160 now.
In order to use ST I'll scale down to 1080.
Have a lovely weekend!
PostPosted: Thu Dec 23, 2021 2:32 pm
In order to use ST I'll scale down to 1080. https://ometv.onl https://chatroulette.top https://omegle.wtf https://bazoocam.cam
Thanks for the awesome information.
